Tire/Wheel Help
Old Oct 16, 2011 | 02:59 PM
GCLL's Avatar
GCLL
Tire/Wheel Help
Hey guys I have a couple questions if you can take a breath from discussing HPFP's.
First, does anyone know if the stock 20" Michelins off my 2011 will fit my 2009 20" rims? I assume they will, but the Michelins look so narrow compared to my 2009 20" rim?
Second, I want to put some Toyo MTs on my 2011. I have a stock FX4 long bed. I don't want a lift. Anyone know how big I can go without rubbing on the control arm?
Thanks,
Ryan
Old Oct 16, 2011 | 04:40 PM
EpicCowlick's Avatar
EpicCowlick
I have Toyo MT 315/60/20's on mine and they just contact the control arm. 305's probably wouldn't but I need the E rating of the 315's. It's not a problem and I only noticed in parking lots when the tires were new.
Old Oct 16, 2011 | 05:30 PM
GCLL's Avatar
GCLL
Thanks Epic. I would like to have the heavier rating also for towing. I had these tires on another truck before and the sidewalls are heavy, great for being loaded down.
I don't have a leveling kit, think it makes a difference?
Old Oct 16, 2011 | 05:36 PM
EpicCowlick
The vertical clearance is not a problem. These tires will work on a non-leveled truck. I leveled purely for aesthetic reasons and beauty is in the eye of the beholder.
Old Oct 16, 2011 | 05:47 PM
GCLL's Avatar
GCLL
So if you did it all over again you would still get the larger size even though they rub a little?
Old Oct 16, 2011 | 05:57 PM
EpicCowlick
I would. I figure that I really need every bit of traction I can get about 1% of the time. My concerns are mostly getting stuck with the trailer in sand or mud and there have been a couple of times that I just barely made it. Was the difference between a 305 and a 315 or was it just my incredible driving skill? I also remember something unique about the 315 size being able to hold more weight. Can't remember off the top of my head but that tire was right in the sweet spot for me.
The marks on the control arm are inconsequential.
Old Oct 16, 2011 | 06:12 PM
GCLL's Avatar
GCLL
Okay great, did you order online? I think the last set I got was like $320 per tire installed.
Old Oct 16, 2011 | 06:16 PM
EpicCowlick
I got mine at the local Les Schwab and they were more expensive. Great tire. I run them unloaded at about 52 psi and inflate to 65 which is the max when towing. I'm pretty sure they hurt mileage but it's worth it to me.
Old Oct 16, 2011 | 07:09 PM
Shepardsonp's Avatar
Shepardsonp
With the larger tires and more rolling resistance, all that make your HPFP work harder?
Old Oct 16, 2011 | 08:14 PM
GCLL's Avatar
GCLL
You had to go there!
slowmans
Sep 12, 2010 05:42 PM
nlfireblade
2004 - 2008 F150
Mar 28, 2009 12:39 AM
spatts
2004 - 2008 F150
Mar 25, 2009 04:17 PM
2001SuperDuty
Mar 3, 2009 08:25 AM
drz400dp
2004 - 2008 F150
Sep 26, 2004 08:36 PM
