Will these tires fit?
Old Mar 27, 2009 | 01:44 PM
nlfireblade's Avatar
nlfireblade
Wondering if someone can tell me if these tires will fit the stock wheels on my 2004 F-150 FX4 SC. I know I need a leveling kit to put them on the truck as well.
Thanks
They are 35 X 13.5 X 18
Old Mar 27, 2009 | 05:02 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
no
the only way would be if you used a 0.75" to 1.25" wheel spacer...and I'm not sure I'd want to use one of them with a 5,000-6,000 lb truck
reason they won't work is the 13.5" width. a 12.5" wide tire is already 1/4" from rubbing the upper control arm. the 13.5" wide tire will be about .5" too wide and be constantly rubbing
Old Mar 27, 2009 | 11:44 PM
nlfireblade
Thanks for the reply. So, you're saying that 12.5 is the largest width I could safely accomodate without further modifications?
Old Mar 28, 2009 | 12:39 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yes...but even that is an iffy prospect. the tire type and brand is a pretty big determiner here as well
A/T tires and M/T tires that have a smaller profile on the side tread will be just fine.
Tires with very aggressive side treads like the Baja Claws won't though. As I mentioned, there will be about 1/4" of clearance between the tire sidewall and the upper control arm.
I had test fit a set of 35/12.5/18 Toyo M/T on my truck with the OEM rims. Fit just fine, but that small clearance freaked me out. There are a few guys on here running that setup though with 0 problems.
BrianjWilson has a 06 truck exactly like mine here somewhere on the site. He is running 35/12.5/18 BFG KM2 mudders and says they are just fine.
93f250tn
27
Mar 27, 2016 10:45 AM
93hatch
26
Oct 4, 2012 06:33 PM
MOERULES
Large Truck
Mar 13, 2010 04:45 AM
XBuford
Dec 5, 2009 05:07 PM
Idiomaticman
Offroad & 4x4
28
Apr 27, 2004 10:26 AM
