1977 4wdf100
Old Oct 16, 2011 | 03:28 AM
diverdan 1961's Avatar
diverdan 1961
1977 4wdf100
I own an Australian built 77 f100 4wd how do you determine what the offset angle is for the 'C" bushings I am in the process of replacing them or trying to anyway, it appears that the ones I purchased may be the wrong offset either that or the finer points of insulator replacement elude me.any help here would be greatly appreciated Cheers Rob
Old Oct 16, 2011 | 06:26 AM
shortride's Avatar
shortride
Welcome to the Ford Truck Enthusiast forums. You are in the wrong forum for your 1977 truck. You will find the information and help you need here.
Old Oct 16, 2011 | 07:47 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Old Oct 16, 2011 | 09:36 PM
HIO Silver's Avatar
HIO Silver
Greetings.
Only if your rig is lifted would you need offset C-bushings.
A stock to 2-inch lift can use standard or 2-degree C-bushings, a two- to four-inch lift requires 4-degree bushings, a lift of more than 4 inches requires 7-degree bushings. IMO, you should think about radius arm drop brackets for a lift of more than 4 inches.
Old Oct 17, 2011 | 12:21 AM
crazy96863's Avatar
crazy96863
I used 2 degree bushings in my 75 which has not lift. They worked fine.
77 short box
Aug 14, 2014 07:53 AM
The67Beast
Offroad & 4x4
Apr 19, 2007 12:17 PM
my79f
Offroad & 4x4
13
Nov 15, 2006 09:38 PM
92 f150300six
Offroad & 4x4
Apr 3, 2005 10:43 PM
biz4two
Jul 5, 2004 11:42 PM
