Offroad & 4x4
C-Bushings
Old Apr 19, 2007 | 07:22 AM
The67Beast's Avatar
The67Beast
C-Bushings
Hi Guys,
I need some clarification on C-bushings. I have a 4-inch Skyjacker suspension lift on my F-100 and want to make sure I have the correct C-bushings.
Energy Suspension says that I need the 4-degree offset bushings for 2"-4" of lift.
Skyjacker says that I need the 7-degree offset bushings for 4"-5" of lift.
It seems that they are contradicting each other, so I am asking for your input, as to what will work the best. To my knowledge 4-degrees is the same as 4-degrees and 7-degrees is the same as 7-degrees. I am leaning towards Skyjacker since they are the manufacturer of my lift.
Thanks
Old Apr 19, 2007 | 09:23 AM
KFX400's Avatar
KFX400
I have a skyjacker lift and they gave me 7 degree bushing for my six inch lift. My father has a 4 inch lift on his bronco and they sent him 4 degree bushings What you are looking maybe a typo or something.
Old Apr 19, 2007 | 12:17 PM
MBBFord's Avatar
MBBFord
IF you don't put longer radius arms or drop brackets I'd sugest putting the 7 degree bushings.
I have a 6" lift wil drop brackets and 7* bushings.
If I would of put a 4" lift w/ drop brackets I would of used 4* bushings.
I'd go with what skyjacker said, but either way would work, and you more than likely wouldn't notice anything bad from one way or the other. I know people you have 4" lifts with stock c bushings.(dumb to me, but no problems for them).
dadstan76
Ford Truck Parts for Sale
Apr 22, 2016 10:54 PM
rwrogers
Mar 26, 2014 05:38 AM
NW 150
Sep 29, 2012 08:18 PM
BigTex68
Mar 28, 2011 10:57 PM
460
Offroad & 4x4
Jul 13, 2006 02:32 AM
