Sponsored by: Real Truck
PTO fluid leak
Old Oct 15, 2011 | 08:12 PM
denfield12's Avatar
denfield12
PTO fluid leak
I have a 2008 F450 4X4 and have fluid leaking out of the PTO. The truck has a 15KW generator that was installed before we bought the truck. Where can I get a new gasket?? Will I loose all of the tranny fluid if I pull off the cover?? My oldest son said that I could use gray RTV as a gasket. Just checking to see if anyone had had this problem before.
Old Oct 16, 2011 | 06:41 AM
bucci's Avatar
bucci
Do you have a PTO installed or is the factory cover over the opening leaking?
If you have a PTO installed, I think you have to use a gasket with the right size thickness because the thickness of the gasket will change the depth at which the gears mesh. If the gasket is too thick the gears aren't meshed deep enough and if the gasket is too thin the gears are jambed/meshed too tight. A PTO leaking is very common.
If just the factory cover is leaking, I don't think it would matter.
Old Oct 16, 2011 | 07:19 PM
denfield12's Avatar
denfield12
Thks for the information. The truck has PTO installed to run 15KW generator. Will have to see if I can find a gasket. Need to change the tranny fluid anway.
Thks
bronco6767
Jan 17, 2015 11:28 AM
luckybturd
Escape & Escape Hybrid
Aug 29, 2007 08:14 PM
99FORD EXPY.
May 7, 2006 01:05 PM
NDrum2005
Oct 29, 2005 03:44 PM
fiveptO
Oct 23, 2003 12:00 AM
