Sponsored by: Real Truck
Changing Rear-End Fluid
Old Oct 21, 2005 | 09:39 PM
NDrum2005's Avatar
NDrum2005
Question Changing Rear-End Fluid
Tomorrow, I'm going to change the fluid in the rear end of two F-350's (2000 and 2002) with open 3.73's at work. What is the capacity of the differentials? Also, Ive changed the fluid on some other older chevys, and noticed that they didnt have a gasket on the diff. cover, just the silicone. Do I really need a gasket on the Fords, or will the silicone suffice?
Thanks.
Old Oct 21, 2005 | 09:57 PM
99f350sd's Avatar
99f350sd
Use the "right stuff " gasket maker in a cheese wiz can its great no gasket needed. Don't use silicone...
Old Oct 21, 2005 | 10:36 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Silicone will be fine... let it "skin" before assembly.
Old Oct 21, 2005 | 11:50 PM
getnbz's Avatar
getnbz
go with right stuff hasnt leaked yet in 3 yrs
Old Oct 22, 2005 | 01:00 AM
Kenworth's Avatar
Kenworth
There is nothing wrong with silicone gasket maker I used Permatex Black on the Dana 80 in my 95 F-450. There was silicone gasket maker used by the previous owner.
You have to follow the directions on the tube some gasket makers say let skin some are assemble parts after applying gasket maker.
You just have to make sure the surfaces are clean and free of old silicone and use some brake clean to clean the surfaces so the silicone will stick.
I don't think I have ever used a rigid gasket on a diff cover.
Old Oct 22, 2005 | 01:50 AM
NDrum2005's Avatar
NDrum2005
Thanks for the replies. I think the silicone that I bought is the Permatex Black, or something similar. Its rated to 650°, so it ought to be fine. I'm changing two trucks, and I bought 2.5 gallons of gear lube, just to be sure I had enough, and wouldnt have to make another trip to the store.
Thanks again
P.S. By changing the fluid myself, and not taking the trucks to the dealer, I'm saving the company $100 per truck.
Old Oct 22, 2005 | 07:11 PM
99f350sd's Avatar
99f350sd
I used the black stuff and it leaked. I saw in a bunch of threads that the right stuff is the way to go. Go figure.
Dick
Old Oct 29, 2005 | 03:44 PM
mattd17's Avatar
mattd17
when i did mine, i just used the orange rtv gasket maker, and it worked really well. i also used the royal puple oil for it. it held a little over 4 quarts i believe.
