9.75 rear leaking fluid
Old Mar 12, 2006 | 09:38 PM
99FORD EXPY.'s Avatar
99FORD EXPY.
why does the local ford dealer tell me that i don't need a gasket on the 9.75 rear end?? anyway 2 months ago i changed the rear fluid used permatex ultra black RTV silicone gasket maker and now its starting to leak the cover and
housing are in great shape clean and dry
i guess i'll buy a sheet of gasket material and cut my own
whats the best gasket material to buy
Old Mar 13, 2006 | 01:02 AM
pronstar's Avatar
pronstar
Your dealer is right, there is no gasket that's requierd for the 9.75. You make it out of RTV.
Old Mar 13, 2006 | 07:47 AM
projectSHO89's Avatar
projectSHO89
Make sure you put a bead of the RTV on both surfaces, let it set 10-15 minutes to get tacky, install and properly torque the bolts, then, if possible, let the truck sit overnight before adding the rear diff fluid.
Steve
Old May 5, 2006 | 03:50 PM
Davez99Expy's Avatar
Davez99Expy
99 Ford Expy, have you got this fixed yet? I changed my diff fluid and used rtv, and can't get it to stop leaking. I was thinking of making a gasket like you mentioned and using rtv to see if it helps, but wanted to hear what you did to fix yours.
Old May 5, 2006 | 04:20 PM
99FORD EXPY.
yes got it fixed make your own gasket don't use cork buy oil res. gasket material and use rtv i waited 15 minutes on the rtv on both sufaces,3000 miles still holding make shore your diff cover is not nicked i purchased a new one from ford i think it cost like 10 to 18 dollars good luck
Old May 5, 2006 | 06:51 PM
wavinwayne's Avatar
wavinwayne
Is the cover a 12-bolt? If so, Advance Auto Parts sells a gasket for that differential. It should be a "Trans-Dapt" brand Differential Cover Gasket Part #9056. AAP will probably have to order it, & could have it to you in 2 business days.
Old May 7, 2006 | 01:05 PM
daveplot's Avatar
daveplot
Recently on the differential fluid changes on my Jeep i've used the Permatex Red RTV. I applied a bead on the differential and took my finger to spread it out, so there was a layer all the way around about 1/16" - 1/8" thick. I waited a few minutes and put the cover on. Waited 24 hours before putting fluid in. No leaks yet for me.
74redone
2004 - 2008 F150
17
Sep 21, 2017 10:08 PM
Ford4Life04
2004 - 2008 F150
Jun 16, 2016 08:51 PM
kirksey228
Mar 16, 2012 12:48 PM
SPreston2001
Aug 14, 2008 04:20 PM
schmidty_dog
Jul 13, 2006 10:39 AM
