Lighted T/C lock switch?
Old Oct 15, 2011 | 04:52 PM
Blueheart's Avatar
Blueheart
Hey guys, I have a quick question. I am installing a tc lock switch and was wanting to use a lighted switch. I am worried about the B+ for the light backfeeding into the pcm because they would use the same ground when on. Anybody have any experience?
Old Oct 15, 2011 | 07:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
triple LED:
https://www.ford-trucks.com/forums/6...l#post10906711
Old Oct 15, 2011 | 10:13 PM
Blueheart's Avatar
Blueheart
Not exactly what I was looking for, I have my switch hooked up to lock the tc when on, just don't have the 12v hooked up for the indicator led. Switch has three terminals, ground terminal to body, load terminal splices into purple/yellow wire, other terminal is supposed to go to 12v, that's what I don't know if it will cause a problem using the same circuit.
Last edited by Blueheart; Oct 15, 2011 at 10:23 PM. Reason: inability to copy and paste from phone
Old Oct 16, 2011 | 11:22 AM
Phy's Avatar
Phy
No, it won't cause a problem. The ground on the switch is only for the LED. The only way there could be a problem is if power were connected to the ground connection on the switch, it could back-feed through the light to the load connection. (That is if it were a regular light bulb... An LED is a light-emitting diode, and diodes only let current pass in one direction, so it shouldn't be able to back-feed through an LED even if power was hooked to the ground...)
*2fords*
May 26, 2012 10:05 PM
Blueheart
Oct 16, 2011 07:27 AM
PowerstrokeJunkie
15
May 20, 2008 11:13 PM
bigtorque
Oct 19, 2006 10:15 PM
mybigredford
35
May 25, 2005 11:39 AM
