Lighted T/C lock switch?
Old Oct 15, 2011 | 04:58 PM
Blueheart's Avatar
Blueheart
Hey guys, I have a quick question. I am installing a tc lock switch and was wanting to use a lighted switch. I am worried about the B+ for the light backfeeding into the pcm because they would use the same ground when on. Anybody have any experience? Thanks in advance.
Old Oct 15, 2011 | 09:55 PM
Blueheart's Avatar
Blueheart
Still crickets? Switch has three terminals, ground terminal to body, load terminal splices into purple/yellow wire, other terminal is supposed to go to 12v, that's what I don't know if it will cause a problem using the same circuit.
Old Oct 15, 2011 | 10:02 PM
BuckHammer's Avatar
BuckHammer
I can't offer you anything except a subscription.
Old Oct 16, 2011 | 07:23 AM
Talyn's Avatar
Talyn
my lighted switch for my gauges is a 2 pole system, it doesn't backfeed.
Old Oct 16, 2011 | 07:27 AM
Talyn's Avatar
Talyn
https://lh6.googleusercontent.com/-6...0/IMG_7167.JPG
Grounds a ground though, the whole vehicle shares 1 ground unless its an isolated circuit.
The only other way you could do it would be to make a circuit up that doesn't allow back-feeding at all.
Though, I doubt an LED would do that.
*2fords*
May 26, 2012 10:05 PM
Blueheart
Oct 16, 2011 11:22 AM
TPM
Sep 11, 2009 05:44 PM
yobuda
Nov 19, 2006 02:00 PM
bigtorque
Oct 19, 2006 10:15 PM
