My unlock stopped unlocking.
Old May 14, 2012 | 08:51 PM
*2fords*'s Avatar
*2fords*
Well today the unlock side of both switches stopped working. It seems odd that the lock side still works as I use that more than the unlock.
So why has it stopped working, and what do I do to fix it?
Thanks in advance.
Oh it's my 92 F-150.
Old May 15, 2012 | 04:38 PM
F150xlt's Avatar
F150xlt
If the Unlock function doesn't work from either switch, the
problem is in the driver side Lock switch or a Black wire at the
driver side Lock switch is not grounded.
If you look at the driver side switch there are 5 wires that
go to the switch terminals. Two Black wires go to individual
terminals and also the same two Black wires are spliced together.
If both Black wires are grounded (normal) the problem is the Lock switch.
To verify the switch is bad use an ohm meter. With the Lock switch not
activated you should measure zero ohms from either Black wire to the
Pink/Yellow wire.
If you read open/infinity, the Lock switch is bad.
Old May 15, 2012 | 08:59 PM
*2fords*'s Avatar
*2fords*
OK Thank You, I'll open it up tomorrow and check it out.
Old May 26, 2012 | 09:10 PM
*2fords*'s Avatar
*2fords*
As I was pulling the switch out, it started to work again. So apparently there was a loose wire on the switch. Which one and how it became loose is a mystery, but as long as it works, I'm not going to worry about it.
Old May 26, 2012 | 10:05 PM
F150xlt's Avatar
F150xlt
NTF (no trouble found).
TexasGuy001
Apr 13, 2016 04:48 PM
Blueheart
Oct 16, 2011 07:27 AM
Larry NCKS
Dec 6, 2009 03:48 PM
matt95stroker
Mar 19, 2007 05:15 PM
PW01
Electrical Systems/Wiring
Aug 22, 2005 02:29 PM
