NPD radiators
Old Oct 17, 2011 | 05:35 PM
  #31
Jetcopterpilot's Avatar
Jetcopterpilot
The Pulleys may be fun, but I am sure the 302 is not as bad as the FE's, I did my water pump, and Single Wire Alternator along with the pulleys at the same time, in hopes of everything being compatible, I am glad that I did, it was a bit of a pain to find all of the right parts for the FE. Dropping the weight down a bunch didn't hurt either, Al of the old pulleys were cast and machined, and very heavy, Installing a lighter pulley set (Aluminum) and a New Damper, definitely improved performance, and made it run just a tick smoother. The old Dampers was not bad >>> YET but it was the two piece with the rubber in between, and I figured it was just a matter of time.
86-IDI
Feb 23, 2019 05:52 PM
krustiy lusti
18
Apr 9, 2017 07:22 PM
leonharu
Mar 19, 2008 09:21 PM
terran05
Oct 1, 2006 10:09 PM
f100drivr
1947 and Older Ford Trucks
Feb 15, 2001 12:20 AM
