NPD radiators
Old Oct 15, 2011 | 08:18 PM
davewave649's Avatar
davewave649
Originally Posted by Jetcopterpilot
according to my research.. 75-78 are the same but 79 is different!
thats what i was afraid of. the water pump from the brand you recommended that fits a 77 is over $400!!!
Old Oct 15, 2011 | 09:58 PM
Jetcopterpilot's Avatar
Jetcopterpilot
Shiiiite!Try to find a mildon.. it will be pricey too or you can go with an edelbrock
Old Oct 15, 2011 | 11:14 PM
davewave649
They have a milodon for $90 so thats what ill go with. Does the radiator have a spot for a thread-in switch for the fan?
Old Oct 16, 2011 | 02:08 AM
Jetcopterpilot
Not unless you use the drain plug location...not a good idea. You can get a local weld shop to put a bung in for a few bucks.... or you can get the slide in style of sensor!
Old Oct 16, 2011 | 04:56 AM
davewave649
Ill prolly just use a slide in type one. Im biking out to where the truck is tomorrow to get a few measurements then ill be ordering most of this stuff monday.
Old Oct 16, 2011 | 02:02 PM
Jetcopterpilot
Yeah I have the slide in style sensor. I put a touch of silicone RTV on it after I got it in place, just enough to keep it from moving. I had a sensor slide out previously then it didn't trigger the fan, learned that lesson.
Old Oct 16, 2011 | 06:23 PM
davewave649
So i went and did some more measurements today, if i go with the radiator you went with there wont be room for me to mount my fan so im having to go with this radiator:
JEGS Performance Products 52017 JEGS Universal Aluminum Radiators
it will fit in the same space my radiator is in right now so it will give me room to mount my fan. The core is slightly smaller tho. Will it cool the engine enough?
Old Oct 16, 2011 | 07:04 PM
Jetcopterpilot
Just the swap to Aluminum will make a nice difference... it is also Cross Flow instead of Down flow, so the coolant is in the radiator a bit longer... aka better transfer rate! It should be just fine!
Old Oct 16, 2011 | 08:21 PM
davewave649
Sweet, now i get to kiss all my money goodbye!!!
Old Oct 16, 2011 | 08:46 PM
Jetcopterpilot
No kidding... but you will have your baby back!
Old Oct 16, 2011 | 11:51 PM
davewave649
True! shes driveable right now but im starting to get worried about that radiator hence the upgrade. All this work probably wont get done till im home for thanksgiving but im ordering everything now so i can start getting everything ready
Old Oct 17, 2011 | 12:00 AM
Jetcopterpilot
Wise choice young man! that is pretty much what I did. I also changed out the pulley set and harmonic balancer at the same time..i switched to a polished aluminum set to lighten things up, and clean up the engine bay a bit!
Old Oct 17, 2011 | 04:31 PM
  #28
davewave649
Just ordered the radiator from Jegs, i decided to wait on the water pump for now. When i did the number crunching it came down to either a new trans cooler or the water pump, i opted for the cooler because its probably only alittle newer than the radiator so it was time for it to go whereas my current water pump is only about two years old. The water pump will get done soon tho!
Old Oct 17, 2011 | 04:42 PM
  #29
Jetcopterpilot
yeah no hurries with that water pump... it is not very old.. worry about it when you need to!
Old Oct 17, 2011 | 05:06 PM
  #30
davewave649
Ill probably replace it when i replace all of the pullies. But thats gonna be a ways out
