I have a 79 f100 with a 400 hp 351 windsor and I have looked through the forums here and cant seem to find a straight answer, Are there any long tube headers that will bolt on and fit?
The 351W is an inch taller (deck height) and a hair wider than a 302. That inch may make all the difference where the collector ends up. It could point directly at yer bellhousing's ears. I know of no bolt on 351W headers for this series BUT ya might want to check out 80-96 series headers.
OR.. (if you are so inclined) get a set of 302 headers and cut'em apart to correct the commensurate difference in height and splay. Meaning, it would require pie-cutting and extending the intermediate tubes to correct the angular differnces - the collectors would need to be kicked outboard. A bit of work but IMO, very doable.
