When and how do you know when to replace your catalytic converter. I have read on a few different sites that after years of use it should be replaced (I don't buy it) They claim more power and better fuel economy.
I know if it is plugged it will not allow it to start due to pressure. Truck is a 1986 Bronco XLT so it makes it 25 years old, should it be replaced or not? Only asking because muffler and tail pipes need doing.
If you are doing the muffler and tail pipe you might as well. I'd recommend getting a new Y-pipe or at least replace the 2 cats with a single hi flow from Magnaflow.
i replaced my cat converters with a hiflow cat from Magnaflow, runs about $60 and is 3" in/out. i am very pleased.
we dont know what motor your have, regardless get the Y pipe rebuilt from scratch. all mandrel bent and what not. make sure the o2 sensor is in the same location as before.
