1978 - 1996 Big Bronco
Cat. replacement ???
Old Oct 12, 2011 | 05:01 PM
mblayton's Avatar
mblayton
When and how do you know when to replace your catalytic converter. I have read on a few different sites that after years of use it should be replaced (I don't buy it) They claim more power and better fuel economy.
I know if it is plugged it will not allow it to start due to pressure. Truck is a 1986 Bronco XLT so it makes it 25 years old, should it be replaced or not? Only asking because muffler and tail pipes need doing.
Old Oct 12, 2011 | 06:05 PM
Edgethis's Avatar
Edgethis
If you are doing the muffler and tail pipe you might as well. I'd recommend getting a new Y-pipe or at least replace the 2 cats with a single hi flow from Magnaflow.
Old Oct 13, 2011 | 08:43 AM
i-w's Avatar
i-w
try summitracing catco cats
Search Results for catco - SummitRacing.com
Old Oct 13, 2011 | 09:44 AM
Kemicalburns's Avatar
Kemicalburns
i replaced my cat converters with a hiflow cat from Magnaflow, runs about $60 and is 3" in/out. i am very pleased.
we dont know what motor your have, regardless get the Y pipe rebuilt from scratch. all mandrel bent and what not. make sure the o2 sensor is in the same location as before.
Old Oct 19, 2011 | 05:10 PM
mblayton's Avatar
mblayton
Does anyone that used a Magna flow high flow cat have a part number? There are so many to chose from.
Also I am pretty sure that I only have a single cat just before the muffler, did newer models go to a two cat set up. Mine is a 1986 with 5.oL
Old Oct 19, 2011 | 08:54 PM
Edgethis's Avatar
Edgethis
I just bought whatever the parts store had in that was 3" in and out. I made sure it was a 3 way that did not require oxidation.
madfrog
Apr 2, 2011 07:39 AM
plapczynski
Feb 12, 2009 05:20 PM
grays31
May 29, 2007 10:15 AM
chixdigit
Jun 28, 2006 10:03 AM
89Bronco_EddieBauer
Exhaust Systems
Feb 16, 2004 05:48 PM
