3 bolt auto hubs 1996
I have a 96 with the 3 bolt auto hubs. I've read all the posts on here and several other forums about how the hubs suck. I'm about to replace with manual hubs.I've tested the 4 wheel drive system and i know I have one hub not locking in, therefore I have a big red two wheel drive. what do I look for inside the hub that will tell me that it's broken? The working hub and the broken look the same. Nothing looks broken or worn excessively. I have cleaned them as they had a ton of grease in them from previous owner.I want to make sure it's not something in the axle shaft or bearings or races. i don't want to change to manuals only to have them not work because of something else. The axle shaft spins and the grooves (splines ?) don't look too worn on the either side.Again, I'm changing to manuals soon just want to make sure I'm not missing anything that could cause my 4 wheel drive not to work. My transfer case locks in. Drive shaft spins, front axle spins, axle shaft on the side with the broken hub spins and won't pull. Any Ideas? __________________
The auto hubs usually strip out on the i.d.
The autohubs are really the weak link in the system so its very unlikely the hubs are good and a shaft/carrier side gear is bad unless broken hubs were swapped out for new ones and he didn't tell you about the internal damage. Since you say the shafts turn along with the d-shaft and the slip in the long side is in good shape this is most probably not the case and you do infact have bad hubs.
Swap them out and never look back. I will almost guarantee you will break the slip joint in the long side or one of the 3 ujoints before a hub gives up. -considering reasonable tire size for the axle of course.
I made the swap this past weekend. Pretty easy job with the right tools. I didn't have a pick set so I made some picks out of clothes hangers and small screw drivers with a grinding wheel. I finally have four wheel drive and can't wait until the next rain storm and hitting some muddy alabama dirt roads
Double truf!
broncoking1994
1978 - 1996 Big Bronco
06-01-2013 03:24 PM
perryau1996
10-18-2011 03:27 PM
CAPTAIN 3747
12-08-2004 08:02 PM
