6.0 Turbo Removal Help
Old Oct 11, 2011 | 08:51 PM
lads_john's Avatar
lads_john
I made good progress removing my turbo to clean it for sticky veins.
Even the dreaded rear bolt didn't give me any trouble.
I'm stuck now trying to pry the uppipe and downpipe from the turbo.
I can't get any leverage and just end up bending the heat shield.
Do the clamps need to be completely removed or just loosened?
The downpipe looks like it fits over a flange on the turbo housing?
Do I need to loosen them at the exhaust manifold?
Old Oct 11, 2011 | 09:04 PM
jkudera's Avatar
jkudera
this is a tip a ford mechanic gave me for this. take an air chisel and with the clamp undone hit the turbo housing with the chisel for a few seconds and the pipes will seperate just from the vibration
Old Oct 11, 2011 | 09:09 PM
NewToDiesels's Avatar
NewToDiesels
I like to undo (loosen) the up-pipe bolts (two on each pipe) to give some wiggle room. This especially helps on the re-installation and getting everything lined up. The air chisel trick is a great tip. The clamps need to rotate very loosely on the pipe to make sure they aren't catching a lip.
If you live up north where salt is used, you'll want to replace those bolts anyway. Down here in LA - we don't see much salt on the roads - just in the air.
Old Oct 11, 2011 | 09:15 PM
U.P. Builder's Avatar
U.P. Builder
Make sure you have the down pipe loose from the cat. I didn't loosen my up pipe bolts but if you can that would help. Then take a pry bar and pry the left side of the turbo at the left front turbo mount bolt and roll it out to the left. It will come.
Old Oct 11, 2011 | 11:26 PM
lads_john's Avatar
lads_john
Should the clamps move freely on the pipes when loose?. My down pipe clamp seems almost fused to the pipe.
Old Oct 12, 2011 | 05:24 AM
wulfman's Avatar
wulfman
John once the clamps are lose or bolts take a long screw driver put against clamps and hit it lightly it will pop lose , mine were same way once they pop lose turbo will come out.
Old Oct 13, 2011 | 12:49 PM
lads_john's Avatar
lads_john
Loosening the down pipe before the CAT and rotating the turbo off the uppipe did it. Thanks for all the help!
Old Oct 13, 2011 | 02:27 PM
U.P. Builder
Glad you got it! After you've done it once it gets much easier.
Old Oct 13, 2011 | 02:41 PM
lads_john's Avatar
lads_john
That's what she said .
Be prepared for the "how do I get these damn pipes lined up" questions when I go to reinstall .
Old Oct 13, 2011 | 03:30 PM
npccpartsman's Avatar
npccpartsman
I always loosen the manifold to up-pipe bolts and EGR cooler bolt before I uninstall/reinstall the turbo. I've never had any luck smacking it back in place with a BFH......
Old Oct 14, 2011 | 06:02 PM
cdev's Avatar
cdev
some days its nice to work on vans the tubo pipes are the easest part
Old Oct 14, 2011 | 06:17 PM
cheezit's Avatar
cheezit
you need a BFPB to go with the BFH
Old Oct 14, 2011 | 09:22 PM
lads_john's Avatar
lads_john
Now - any tips on separating the central housing from the turbo. I've tried by biggest BFH and it's barely budging. The TSB suggests using a brass drift. Is that a brass chisel? My LAPS has brass punches but don't see how that would help.
Old Oct 14, 2011 | 09:42 PM
lads_john's Avatar
lads_john
Ne'er mind. My other BFH did the job . Little too trigger happy on the computer.
KEO
Dec 14, 2009 06:33 PM
KRDiesel
Nov 18, 2009 07:36 PM
skyrider4000
Feb 24, 2008 05:23 PM
redneckboy
Mar 30, 2007 11:32 AM
bloomy63
Sep 3, 2006 02:45 PM
