IPR %
Old Oct 10, 2011 | 03:31 PM
bama29fan's Avatar
bama29fan
IPR %
Was playing with AE on my dads (new to him) 05' 6.0
he got on it a little bit one time (probably not fully WOT) as i watched the computer. His ICP went up to 3900+ and the IPR climbed to around 75%.
Is this normal for a 6.0 or should it stay closer to 50% (max) like on a 7.3?
Thanks for your help.
Old Oct 10, 2011 | 04:09 PM
NewToDiesels's Avatar
NewToDiesels
That's where mine heads at WOT. I think the max I've seen on IPR % was 79% and a nick over 4,000 PSI (max should be 4,005 PSI iirc)
Old Oct 10, 2011 | 04:12 PM
cartmanea's Avatar
cartmanea
Sounds fine to me. You're reaching max ICP without maxing our your IPR. The main thing to watch is at idle you should be under 30% IPR.
Old Oct 11, 2011 | 09:01 AM
bama29fan's Avatar
bama29fan
Cool thanks y'all
Old Oct 11, 2011 | 09:34 AM
BLADE35's Avatar
BLADE35
WOT not a very good indicator
you want to check IPR% at HOT IDEL
Old Oct 11, 2011 | 10:15 AM
bama29fan's Avatar
bama29fan
10/4...if i remember right it was like 22% at hot idle.
Thanks
Old Oct 11, 2011 | 10:43 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
I'm not sure about my IRP % but I have seen my ICP around 4300 at WOT. But I'm running bullydog on performance setting when it does that.
Old Oct 11, 2011 | 03:50 PM
wulfman's Avatar
wulfman
My hot idle IPR is between 21 % and 22% always and ICP 640ish
Old Oct 12, 2011 | 10:44 AM
bama29fan's Avatar
bama29fan
IIRC...that sounds like what his was running at as well.
Thanks
dp1181
Jun 27, 2017 06:41 PM
sand_fiend
Oct 23, 2011 08:31 PM
jonesy23
Mar 20, 2010 10:20 PM
Hoosierbuckslayer
Aug 5, 2009 12:12 AM
mozzy1234
Sep 6, 2005 07:41 PM
