Sponsored by: Real Truck
Need help with brake problem
Old Oct 9, 2011 | 05:49 PM
nightshadow0123's Avatar
nightshadow0123
Hi everyone..i drive a 2000 ford f250 7.3L diesel (V8) and have had no problems except i have noticed a squealing coming from the passenger front wheel area. i assume something is wrong with my brakes?!? is this a common problem and how to i fix/diagnose this? the squealing stops only when i depress the brake pedal - the rest of the time it is present and getting louder. is it possible my brake pad is rubbing the rotor? im not sure what to be looking for but i am taking the wheel off tomorrow for a closer inspection. any insight would be much appreciated!! thanks!
Old Oct 9, 2011 | 05:55 PM
HLDDWGN's Avatar
HLDDWGN
Most likely you have debris between the pad and rotor; or it's the wear tab letting you know it's time for new brake pads.
Old Oct 9, 2011 | 05:58 PM
HLDDWGN's Avatar
HLDDWGN
If it is the wear tab and it's only on that side you have a caliper hanging up. A proper"brake job" will alleviate the problem.
Old Oct 9, 2011 | 06:21 PM
ken kenmnedy's Avatar
ken kenmnedy
this has happend to me twice turnd out to be a pice of gravel each time if you are lucky just remove the stone and go on..... if not well it cost me a rear rotor 2nd time good luck
Old Oct 13, 2011 | 04:50 PM
nightshadow0123
thanks guys for the ideas. i just took the wheel off today and the caliper and brake pads...no debris - no damage to rotor - brake pads look ok so i used a c-clamp to reset the caliper put it all back together and test drove...the squeal is gone..probably just a sticky caliper that held the pad to the rotor gently.
Old Oct 13, 2011 | 07:46 PM
HLDDWGN's Avatar
HLDDWGN
Good to hear, most likely sticky caliper hardware.Once you took it apart you free'd it from the sticky position.
anthonym92
Apr 9, 2015 10:55 PM
Tri865
Jan 22, 2014 04:08 PM
steveaus
24
Jul 16, 2011 03:59 PM
ford9c
2004 - 2008 F150
Jun 1, 2006 09:08 AM
my79f
Mar 25, 2004 03:26 PM
