brake problem
Old Mar 24, 2004 | 05:32 PM
my79f's Avatar
my79f
brake problem
today i had my brother take my truck to get inspected since i dont get my lisence till next week. and on the sheet of problems he brought home it said that under hard brakeing the truck pulls to the left. i went and checked this and sure enough it did pull. What could be the problem, maybe bad pads up front and out back. some advice would be excellent.
Old Mar 24, 2004 | 07:21 PM
ChargerHemi's Avatar
ChargerHemi
My F-150 does this. My advice: Don't brake hard unless absolutely necessary. And in the event it is necessary to brake hard, you'll already be alerted and gripping the wheel hard enough that it's not worth worrying about.
It could simply be a small problem of more fluid being sent through the front-left brake line or something to that effect. But as I said, it's nothing to worry about unless you feel it's a serious problem.
Old Mar 24, 2004 | 09:59 PM
jamessl1's Avatar
jamessl1
how old are your calipers? the piston on the right one might be seized up or not expanding enough. Check and see if your pad wear is minimal on the right. Inspect rotor to see if you are getting pad contact on both sides of the right rotor. If your left rotor is badly warped it can cause it to pull some. Good Luck
Old Mar 24, 2004 | 10:01 PM
jamessl1's Avatar
jamessl1
I forgot to mention that excessive ball joint wear can cause this problem. also loose or excessively worn bearings.
Old Mar 25, 2004 | 01:39 PM
Phinxter's Avatar
Phinxter
I think more likely the left drum is mis-adjusted or there is a problem with your right drums auto-adjuster, I certainly doesn't hurt to check them all out though.
Old Mar 25, 2004 | 01:46 PM
73Custom's Avatar
73Custom
Never, never drive a vehicle with questionable brakes. It's one thing to endanger your own life - but bad brakes are dangerous for everyone else on the road with you.
There is something wrong that needs repaired - that's exactly why there is a safety inspection. Get it fixed properly.
- I'm getting off my soap box now...
Marty
Old Mar 25, 2004 | 03:26 PM
my79f's Avatar
my79f
thanks for the help
