brake problem
Old Apr 8, 2015 | 10:37 PM
anthonym92's Avatar
anthonym92
brake problem
ive been having some issues with braking in my f150. when i first go to depress the pedal the brakes seem to barely work but once i let off and hit the pedal again then it brakes really good and will even lock up. ive noticed when doing wheel bearings that my driver side rotor was way thinner than my passenger side rotor. i replaced the brake pads but it didnt do much to help. any advice would help. thanks guys.
Old Apr 9, 2015 | 12:25 AM
joey2fords's Avatar
joey2fords
sounds like your caliper on the drivers side may be seized or sticking. also take a look at the brake line on that side to make sure that it isn't pinched or kinked.
Old Apr 9, 2015 | 10:12 PM
anthonym92's Avatar
anthonym92
i replaced the brake line already so i will take a look at the caliper
Old Apr 9, 2015 | 10:13 PM
anthonym92's Avatar
anthonym92
but wouldnt a sticking caliper cause my truck to turn to one side?
Old Apr 9, 2015 | 10:50 PM
Bruners4's Avatar
Bruners4
Check your rear brake shoe adjustment. If they are too loose, it will cause the brake pedal to be very low the first time that you depress it but will pump up the second or third pump. Very easy to check. Little rubber adjuster plug on the bottom of the brake backing plate. Self adjuster should only allow you to turn the star-wheel in the direction to tighten them. Be careful to not over tighten them! I adjust them with the wheels off of the ground so that I can spin the wheel while adjusting. You can hear the brake shoe drag against the drum slightly.
Old Apr 9, 2015 | 10:55 PM
anthonym92's Avatar
anthonym92
i will definitely check that out tomorrow. thanks for that
1oldlongbed
Jun 14, 2017 08:57 PM
yasky69
Modular V10 (6.8l)
Dec 30, 2010 09:29 PM
JETSLED
Mar 14, 2007 08:33 PM
rkshipley
Apr 23, 2006 09:54 PM
NH-Hottie
1978 - 1996 Big Bronco
Oct 23, 2003 11:52 AM
