pulling 390 w/ C6
Old Oct 8, 2011 | 10:51 PM
2tone250's Avatar
2tone250
pulling 390 w/ C6
I bought a 76 F250 with 390 and C6 as a parts truck and will be pulling the motor. I just wondered if there were any tips or tricks to doing it? I'll try to post up pics as it happens.
Old Oct 9, 2011 | 01:44 AM
weez440's Avatar
weez440
to give you more room you can pull the front clip or just the front grille. i usually opt not to but beings you are pulling the tranny as well i would go this route. and i would deffinately pull the hood off. and last but not least i would offer beer to a buddy or two to help you out. it makes things easier and actually more fun in my opinion. and remember every 15 minutes take a beer break
Old Oct 9, 2011 | 07:33 AM
RunninD's Avatar
RunninD
I pull the entire front clip. 8 bolts per side, the wiring harness, (if not butchered) just unplugs. Undo the radiator hoses, and then lift out the entire front. pull the hood, and then its all out in the open! re-install is just a simple matter of going backwards! The bonus of this method, to me, is the fact that when re-installing the front clip, you won't need to fight to get the proper body alignment! 8 bolts per side aligned with the visible positioning of where they came from.
Old Oct 9, 2011 | 04:32 PM
cj06's Avatar
cj06
if the parts truck is in bad shape and you just plane on using the engine and tranny then take a sawzall or torch and cut the front off then yank the engine
decaruby
Apr 18, 2016 11:32 AM
Raptor119
Jun 11, 2014 02:45 AM
2tone250
Oct 9, 2011 06:24 PM
2manyprojectsatonce
19
Dec 7, 2009 06:28 PM
78ford351m
Apr 30, 2006 05:33 PM
