Sponsored by: Real Truck
ESOF fix
Old Oct 8, 2011 | 06:49 PM
Sparky2531's Avatar
Sparky2531
ESOF fix
The people on the FTE forums are the best.
After reading about someone else's problems with their ESOF I followed a link that was published in the thread and arrived at:
http://www.dieselsite.com/1999-2004f250f350dieselsite4wdesofhosekit.aspx
What I thought was a little pricey, turned out to be a very high quality answer to my problem. The parts showed up in only a few days and took a total of 15 minutes to install. Now my ESOF works perfectly, and with quite a bit of authority. To say the least, I'm quite disappointed in Ford's choice of garbage vacuum lines used in an area (the front wheel wells) that is exposed to the worst that can come off the front wheels.
I highly recommend dieselsite.com. Thanks to you guys on the FTE forums.
Old Oct 8, 2011 | 07:27 PM
acf6's Avatar
acf6
Thanks for the link! looks like i know what i will be ordering next
Old Oct 8, 2011 | 08:01 PM
fordboy67's Avatar
fordboy67
I still feel the swap to Warn Premium or Milemarker hubs is a better investment. It eliminates the vacuum lines altogether. Just my opinion
Old Oct 8, 2011 | 09:00 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
$70 buys a lot of regular rubber hose.
I can see extreme off-road, with a lot of brush, causing issues that stainless-steel-braided lines would help. But I think the brake lines would also suffer from that sort of abuse
The rest of the system will still cause problems, the plastic vacuum lines upstream, the vacuum solenoid, etc.
Of course, it does LOOK cool
F150hogger
1997 - 2003 F150
Feb 11, 2019 07:05 PM
ExPACamper
Jul 27, 2016 09:36 PM
jim0517
Oct 8, 2011 07:21 PM
GMan1
Jul 18, 2009 07:42 PM
afreemanmd
Jan 2, 2007 06:00 PM
