PCV valve for the V8 flathead
Old Oct 8, 2011 | 04:26 PM
51PanelMan's Avatar
51PanelMan
I had this forwarded to me for sharing. Supposed to eliminate blow by and condensation in the crankcase. Has anyone heard of or tried it? Any pros or cons? It's cheap enough to buy for my 51 to have for "just in case".
Jamco Suspension - 49-53 FORD FLATHEAD PCV VALVE KIT Jamco Suspension, Your #1 Source for Hot Rod Brakes and Suspension!
Old Oct 8, 2011 | 05:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I wish they'd show where the hoses on the right go, I can't figure out what they're doing. I have PCV I made for less than $10 and it works fine.
https://www.ford-trucks.com/forums/6...or-an-8ba.html
Old Oct 8, 2011 | 05:17 PM
Damifiknow's Avatar
Damifiknow
Go to local parts store and make your own and save 40 bucks.
Old Oct 8, 2011 | 05:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
In their defense, that is a nice looking piece with a nice O-ring seal where it plugs into the draft tube hole (Hecho in china no doubt, probably cost them under a buck)
I just can't figure where the hoses are going after the Tee; one to the wipers, perhaps. But the one that goes down is a mystery. I can't see where it connects to the intake, the normal place has a hose on it (for the wipers no doubt).
Old Oct 8, 2011 | 06:13 PM
51PanelMan's Avatar
51PanelMan
Here's a copy of their installation instructions:
Start by removing the factory two piece vent tube. To do this, it is easiest to tap it with a hammer to
loosen then pull out. Make sure the hole in the manifold is cleaned of all sharp edges. Use a file or reamer for
this. This is to prevent damage to the “O” ring on the new aluminum valve. Next, rub a little bit of motor oil on
the rubber “O” ring and gently twist and push into the manifold up to the shoulder on the valve.
Now at the base of your carburetor there is a vacuum fitting on the intake manifold that supplies vacuum
to the factory wipers. You will cut this vacuum line and install the supplied “T” fitting between the manifold and
the wipers. Install is now complete.
You will notice an increase in the RPM’s . You will need to adjust the idle on your carburetor now that
you have introduced a new source of air into the manifold. At idle, you should be between 600 and 800 RPM’s.
You are now finished.
This will eliminate blow by smoke from the original vent tube and filler tube as well as keep condensation out of
the crankcase.
www.
Old Oct 8, 2011 | 07:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Hmmm... OK. I don't have vac wipers, but it seems to me you need to use a separate vac source for the wipers when using PCV, or you'll think you are going up a hill even at a stoplight. (True whether you build your own or use the kit).
Old Oct 8, 2011 | 07:07 PM
52 Merc's Avatar
52 Merc
I looked at it and it says to tee into the wiper vacuum line. The hose on the right goes from the manifold carb base to the wiper motor. Without vacuum wipers, you'd just plug into the manifold. If you look at the size of the hose, it's tiny like the wiper hose. Not nearly as big as an OEM PCV system would be. It's a cool piece, but I think a better system could be made for far less, like Ross said, using a larger, proper PCV sized hose. My 2c.
Old Oct 8, 2011 | 07:52 PM
Doc's Avatar
Doc
So how much do you guys think that will affect vacuum supers? As for the increased RPM's, I am sure they are right, but isn't that replacing one air source for another one?
Old Oct 8, 2011 | 08:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Sent from your auto-correcting phone Doc?!
The vacuum tap for the wipers under the carb has an orifice, very small, probably 1/16". I was tempted to open it up to allow more flow when I did PCV. If I had vacuum wipers I would for sure, or use a separate tap.
Old Oct 8, 2011 | 09:22 PM
52 Merc's Avatar
52 Merc
The flathead engine I'm going to use came from a big truck, so it has an extra, larger port on the intake carb base that went to the power brake booster. I figure that would be a good place to hook up a PCV. It's sized about right.
Old Oct 8, 2011 | 09:25 PM
Doc's Avatar
Doc
LOL. You nailed it! I hate this phone. I am glad to see you say that about the wipers. To me, their performance would suffer even more than they do already.
Old Oct 8, 2011 | 09:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You can always run the dual-diaphragm fuel pump and a vacuum reservoir...
Old Oct 8, 2011 | 10:03 PM
john smith jr's Avatar
john smith jr
I lost use of my vac wipers completely after installing it on my flattie. Also had the problem of blow by entering my cab thru the vac wiper motor under dash. I ended up disconecting my wipers from the vac line since i still have a primered body and dont drive it in the rain.
Old Oct 8, 2011 | 10:27 PM
52 Merc's Avatar
52 Merc
Do those pumps work well? I found one on ebay to use on my engine. It sounds like it should be a good way to go to have better working wipers. Not that I'm too worried about it with our annual precip of only 7", and it's not going to be a daily driver. But I did question how it hooks up. The instructions in the service manual are unclear to me.
Old Oct 8, 2011 | 11:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I would do it by running a vacuum reservoir, with two lines to it: one from the manifold, with a check valve in it (easy to find at the boneyard, all cars use them for the HVAC control vacuum), and the other from the diaphragm pump, also with a check valve. How well do they work? Couldn't tell you but it has to be pretty good, the State of California required them on all cars/trucks with vac wipers. And they know what's best for all of us!
I don't see how you could get blowby into the cab thru a vac hose that is sucking air out of the cab, John? Something must be wrong there. A check valve would prevent it for sure.
sseebart
Dec 28, 2023 10:38 AM
82airborne82
Oct 2, 2010 09:52 PM
countryboy116
1983 - 2012 Ranger & B-Series
Jun 23, 2007 10:39 PM
V8 Andy
Feb 17, 2005 03:31 PM
77fromheaven
Feb 17, 2003 01:59 PM
