Where to connect PCV ?
Old Feb 17, 2005 | 03:15 AM
V8 Andy's Avatar
V8 Andy
Hi,
my question today.
Where i have to connect the PCV ? I mean i have the 351w - 1992 - F250.
One hose is connected to the passanger side crankcase and the other hose to the Intake, ok, BUT there´s another connector at the valve.
Well now i´m confused.
Can anybody help me ?
Thanks
Old Feb 17, 2005 | 09:02 AM
95X15's Avatar
95X15
Check your vacuum routing decal on hood/ radiator support- 95 manual says some pcv valves are connected to the evaporator/purge system. Good luck.
Old Feb 17, 2005 | 09:52 AM
EPNCSU2006's Avatar
EPNCSU2006
I think you just have an aftermarket universal valve. Your truck probably only uses one of the outlets - there should be a plug supplied with the valve to seal off the extra hose barb.
I've never heard of the pcv connecting to evaporative emissions control...
Old Feb 17, 2005 | 10:24 AM
V8 Andy's Avatar
V8 Andy
Ok,
i saw at "advance parts" that there´re to kinds of valves for mine.
But the diagramm shows only one connection, is this right ?
Thanks
Old Feb 17, 2005 | 12:17 PM
midlf's Avatar
midlf
I just bought a PCV valve at NAPA for my '93 F-250 5.8L. They gave me one with two connections, one large and one small. They said to plug the smaller one. The valve package contains a small plug to do this.
On a related topic, it has been recommended that I disconnect and plug the PCV port at the right rear of the intake and reconnect the PCV valve to the manifold tap where the other vac lines connect. This is to prevent problems with the #8 cyclinder. Is this correct?
Old Feb 17, 2005 | 02:27 PM
qman's Avatar
qman
I replaced my PCV and got the same double connector eventhough mine was a single. It comes with a little piece of plastic for plugging the extra hole. That's probably all you have to do (V8Andy). And midlf, I've seen this re-routing of the PCV talked about in this forum. Do a search on "plenum" and you should find what you're looking for. I thought it was for older trucks though. I guess the hot PCV gasses caused the #8 cylinder to overheat and valves would burn up or something.
Old Feb 17, 2005 | 03:31 PM
V8 Andy's Avatar
V8 Andy
OK
i´ll do so, and plug the upper hole.
at all helpfull people out there : THANKS A LOT
85Blondie
Jun 17, 2012 07:15 AM
taylorjgreen
Mar 20, 2011 11:09 AM
mikemic
1983 - 2012 Ranger & B-Series
Feb 26, 2006 03:15 PM
tapenick
Feb 17, 2003 09:23 PM
mforren
May 25, 2000 03:23 AM
