Tire Size??
Old Oct 6, 2011 | 10:17 PM
Zizz's Avatar
Zizz
Tire Size??
I have a 1994 F350 with a 4" suspension lift, the kit says the max tire size is 36", if i put on a 3" body lift, what size tires could i max
Old Oct 6, 2011 | 10:31 PM
White 97 xlt's Avatar
White 97 xlt
Forget the body lift and have a USABLE truck!!! Body lifts weaken the truck besides they look goofy, tires bigger than 36 inches are going to be big enough to rob your trucks performance unless you put some $$$ in gear changes..
YMMV
Old Oct 6, 2011 | 10:40 PM
GNR22's Avatar
GNR22
well if its an F350, you have a 351w or bigger. if you have a 351, dont go any bigger than 35s, actually id stick with 33s (but go big or go home i guess) itll suck the power right out of it, and itll look cosmetically fine being just 35s, and if you have a big block or a 7.3, how much power do you want to suck out of it putting big tires on? dont put on a body lift, that would be foolish. but if youve got yourself talked into it, id guess youd be able to fit 38s with some pretty offset rims.
Norse68
Jun 28, 2017 04:04 PM
pistolpete88
Feb 25, 2011 10:16 PM
Jesse Cupps
1997 - 2003 F150
Jul 26, 2008 09:54 AM
lcpln8
1978 - 1996 Big Bronco
16
Feb 14, 2008 04:27 PM
Dels86
Mar 1, 2004 01:14 PM
