I need the 2 plastic insulators that go on the front leaf springs, (where the center pins are) as well as the center pins themselves. Anywhere online you can get them???
I am going to swap in my 6,000lb X-Code springs before plow season gets here, but I removed the original center pins because they were VERY rusted, and the plastic was all cracked and broken.
I called the local Ford Steeler, and they couldn't help. Basically, he couldn't find the parts, and is supposed to "call you back when I find them."
Well... no call, and the other auto parts stores don't have them. I would rather not travel 45 miles to the only "Spring" shop around.
