I do alot of short trips. When I rebuilt my engine at 130K I replaced the clutch as long as I was in there. I measured the clutch disc and compared to the new one I was putting in. The old was only wore .015. Not too bad I thought . Coulda easily run 200K. It's all in how a fella uses the clutch.
I replaced my clutch at 112,000 miles... I think that my truck was abused before I got it... If I knew what i know now , then I would't have bought it...
Like PigFarmer said it's all about how you use the clutch. A few years ago I worked on an Escort that the clutch was shot. Put in a new one and then next week it was back slipping and smoked again. Same deal a week later. The kid's dad took the car away from him and it hasn't been back with clutch problems again
Trying not to ride or otherwise abuse the clutch, and the question from your other post about how to prevent wheel hop when you spin the tires from a stop don't really seam to go hand in hand. Spinning your tires is abusing your equipment and will probably lead to shorter life spans for any number of driveline components.
But we aren't talking about lighting tires up every day here. I last bought tires 18 mos and 60,000 kms ago and I suspect their is 50,000 kms left in them. I'm not beating on anything continuosly. That's why they are seperate posts right??
If you don't ride the clutch chirping the tires you aren't really causing excessive clutch wear. If you wind it out to 4 grand then dump the clutch that's a different story. Otherwise, if clutch is fully engaqged you aren't causing more clutch wear than otherwise running full hp through the drivetrain.
My concern is that wheel-hop adds to drive train fatigue as it is ubrupt tension and lack thereof on drive train components.
It all depends on how you drive a vehicle.
The clutch would be gone before 191,000 kms if I were badly abusing it.
It is all dependent on conditions (hwy/city) and good the operator is at shifting and taking off. My engine doesn't usually go above 700rpm while taking off, I've seen people rev to 1500, that just wears it out faster than needed. The truck I had before this one was a 95 and had 100k mi on it when the clutch went out, it went pretty suddently too, within 10-15 miles I couldn't put it in 1st and barely into 2nd.
Yep that's my worry.
Alot of clutches seem to be gone by 100K. I have a little over 120 on mine now. Works great, doesn't slip. I'd like to see it go to 200K but not sure if that's realistic.
