460 running rich
Old Apr 9, 2003 | 08:57 PM
sljim's Avatar
sljim
460 running rich
Have a 1990 E350 with 460 engine that runs realy rich won't idle and runs very rich and blows black smoke runs like the chock was fully closed if it had one ,undrivable changed o2 and map sensor checked air filter and tubes bo change am not getting any codes
Anyone with any ideas would be a help
Old Apr 9, 2003 | 09:43 PM
pfogle's Avatar
pfogle
460 running rich
have you pulled the codes?
Old Apr 9, 2003 | 09:54 PM
c_rossman's Avatar
c_rossman
460 running rich
Pull the vacume hose off of the fuel pressure regulator. If there is gas in the line thats whats wrong. Replace the regulator and you would be good to go. I would go with an adjustable one, they are about the same price.
Old Apr 11, 2003 | 12:34 PM
sljim's Avatar
sljim
460 running rich
Checked the regulator hose no fuel checked the codes no codes getting a fuel pressure gauge tonight to see what the pressure is could be a stuck regulator let me know what you think if it is how do you disconnect the lines any ideas would be welcomed.
**edited capital letters.
Old Apr 11, 2003 | 03:01 PM
c_rossman's Avatar
c_rossman
460 running rich
Look on the passenger side fuel rail, There should be a shrader valve, looks like a tire valve. The pressure tester would hook up there. Check the vac. line to the Map sensor, if and doubt replace it. I had that happen to my thunderbird. an excessive fuel pressure would only cause rich condition at idle and wot. stock pumps can only produce about 60-70 max psi.
Old Apr 12, 2003 | 07:45 PM
sljim's Avatar
sljim
460 running rich
checked fuel preasure ideled at 45 jumped to 90 will be repacingh the reg. unless hear differant
Old Apr 12, 2003 | 09:33 PM
c_rossman's Avatar
c_rossman
460 running rich
you must have a good pump in that rig. I would start with the regulator.
Old Apr 13, 2003 | 04:43 PM
sljim's Avatar
sljim
460 running rich
replaced regulato real pain in the butt to get at fuel pressure says around fourtyish runs now but still seems a little rich will take it for a blast later to how it works
