Rear Differential
Old Oct 3, 2011 | 09:28 PM
rdraidr's Avatar
rdraidr
Rear Differential
I've looked, but I don't see any information on how to change the fluid in the rear diff on a '03 Expedition. Looks like a daunting task as there is a box beam directly behind it. I see the bottom plug, but what about the fill plug? Anyone out there ever remove the rear plate? I've done this with PUs before, much easier. 91K on the ODO and don't know if this has ever been changed. Thanks.
Old Oct 4, 2011 | 07:19 AM
alwaysfords41's Avatar
alwaysfords41
It's an easy job, everything is easy to get to. The fill is further up towards the drive shaft, follow the housing forward, it is a 3/8" square drive. Driver's side I think. Make sure you can get the fill out first before you pull the plug.
Old Oct 4, 2011 | 07:28 AM
broncoholic's Avatar
broncoholic
Mine had a fill plug on the forward driver's side of the diff. It used a 3/8's square drive.
Old Oct 4, 2011 | 09:38 AM
alloro's Avatar
alloro
I suggest removing the spare tire first. The amount of working space doing that gives you is amazing.
dracond
Jul 22, 2015 06:08 AM
DieHardChief
21
Nov 14, 2013 08:55 AM
jjurva!
Jul 26, 2013 01:13 AM
1stexpy
May 25, 2005 06:46 PM
