1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Rear Differential
Old 10-03-2011, 09:28 PM
rdraidr's Avatar
rdraidr
rdraidr is offline
Rear Differential
I've looked, but I don't see any information on how to change the fluid in the rear diff on a '03 Expedition. Looks like a daunting task as there is a box beam directly behind it. I see the bottom plug, but what about the fill plug? Anyone out there ever remove the rear plate? I've done this with PUs before, much easier. 91K on the ODO and don't know if this has ever been changed. Thanks.
Old 10-04-2011, 07:19 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
It's an easy job, everything is easy to get to. The fill is further up towards the drive shaft, follow the housing forward, it is a 3/8" square drive. Driver's side I think. Make sure you can get the fill out first before you pull the plug.
Old 10-04-2011, 07:28 AM
broncoholic's Avatar
broncoholic
broncoholic is offline
Mine had a fill plug on the forward driver's side of the diff. It used a 3/8's square drive.
Old 10-04-2011, 09:38 AM
alloro's Avatar
alloro
alloro is offline
Received 4,211 Likes on 2,453 Posts
I suggest removing the spare tire first. The amount of working space doing that gives you is amazing.
dracond
07-22-2015 06:08 AM
DieHardChief
21
11-14-2013 08:55 AM
jjurva!
07-26-2013 01:13 AM
1stexpy
05-25-2005 06:46 PM
Quick Reply: Rear Differential
