steering coupler disk question
Old Sep 30, 2011 | 02:15 PM
Ohydro91's Avatar
Ohydro91
It disconnected and this metal piece is all bent up and I'm not sure how to take the rubber disk off, and put it back together. I can send picture to someones email I can post them from my phone. The truck is a 1980 f150 302
Old Sep 30, 2011 | 08:34 PM
Franklin2's Avatar
Franklin2
Here's a picture.
AutoZone.com Repair Guide Image
Autozone sells the disc under part number 31002 or 31000
Old Oct 1, 2011 | 04:49 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
FYI, this is called a 'rag joint'
Old Oct 1, 2011 | 05:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ArdWrknTrk
FYI, some people call it a 'rag joint' because the Ford description is a mouthful.
E0TZ-3A525-A .. Coupling-Steering Gear Input Shaft to Steering Column Shaft.
1980 F100/350 & Bronco with P/S / 1981 F100/350 & Bronco with P/S before 2/1981.
E0TZ-3A525-B .. Coupling-Steering Gear Input Shaft to Steering Column Shaft.
1980 F100/350 with M/S / 1981 F100/350 with M/S before 2/81.
Not available after 2/81, only furnished with the 3B676 Lower Steering Shaft and Coupler Assy.
Old Oct 1, 2011 | 05:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Bill,
I was not aware of the Ford nomenclature for this flex coupling, but if you were to walk into the auto parts store and say that you need to replace the "rag joint" at least they would know what you were talking about.
Old Oct 1, 2011 | 08:32 AM
Franklin2's Avatar
Franklin2
Bill,
The HELP! people are the ones that carry this in the parts stores. The call it a "Steering Coupling Disc". It took me awhile to find it, and "rag joint" doesn't work, even though everyone knows what that means. Those part numbers work also in the autozone search box.
I seem to recall some guys on here using this HELP! part, and they may have had to drill the holes out a little bigger to make it work.
Old Oct 1, 2011 | 08:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have used the Dorman (HELP!) product and had to use some low headed bolts and Nyloc jamb (shallow) nuts instead of the rivets to install it IIRC.
Old Oct 1, 2011 | 11:45 AM
Ohydro91's Avatar
Ohydro91
I asked for rag joint and they didn't know what it was. But any way I'm looking for a way to fix it please. Still haven't figure out the broken metal piece.
Old Oct 1, 2011 | 12:10 PM
NumberDummy
E0TZ-3A525-A .. Coupling-Steering Gear Input Shaft to Steering Column Shaft / Obsolete
Applications: 1980 F100/350 & Bronco with P/S / 1981 F100/350 & Bronco with P/S before 2/1981.
LAST MSRP: $77.17 / Dealer net cost: $46.30.
BAYER FORD in Comanche TX has ONE = 325-356-2777.
MARTIN FORD SALES in Union Grove WI has ONE = 262-878-1241.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
AUTOS VEGA in San Juan Puerto Rico has ONE = 787-782-4030.
No other FoMoCo Dealer, or obsolete parts vendor has any.
E0TZ-3A525-B .. Coupling-Steering Gear Input Shaft to Steering Column Shaft / Obsolete
Applications: 1980 F100/350 with M/S / 1981 F100/350 with M/S before 2/81.
Last MSRP: $62.35 // Dealer net cost: $37.41.
PIONEER FORD in Groton SD has ONE = 605-397-2311.
GREEN SALES CO. has ONE.
MANDERBACH FORD in Temple PA has ONE = 810-929-3683.
HIGH BUCK!! BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
BAYER FORD has TWO.
No other FoMoCo Dealer or obsolete parts vendor has any.
Old Oct 1, 2011 | 02:35 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Can you post a picture of what's broken?
Old Oct 1, 2011 | 08:31 PM
Ohydro91's Avatar
Ohydro91
I'm not sure how to from a phone. I can email you a picture.
Old Oct 2, 2011 | 10:42 AM
cadunkle's Avatar
cadunkle
The rag joint I got to replace mine was a different size although listed for the application. I probably could have modified the shaft to make it work, but I opted to go with a solid steering shaft with a ujoint. Tighter steering and more road feel... Better than a rag joint. I might have ordered it from LMC, I forget.
Old Oct 2, 2011 | 12:31 PM
Franklin2's Avatar
Franklin2
Do you get more noise coming from the steering wheel? That's the main reason the disc is in there, to eliminate the hydraulic hissing noise from the power steering box and system coming up through the column.
I believe Borgeson does make a u-joint with rubber made into it for the same reason.
Old Oct 2, 2011 | 03:25 PM
cadunkle's Avatar
cadunkle
There is some more noise, but it's a truck not a Lincoln. The increased durability, more responsive steering, and better road feel more than make up for it.
ddepumpo
Apr 9, 2018 03:25 PM
OldgreenF1
Jan 10, 2017 08:07 PM
CharlaineC
18
Oct 22, 2014 05:27 PM
brett_d
Feb 27, 2008 06:16 AM
