Need help
Old Oct 2, 2011 | 11:33 AM
Tknight85's Avatar
Tknight85
Need help
Im trying to get the fan clutch fan and the pulleys off of my 84 f250 with the 460 bought a Chilton manual but it's about worthless I've pulled every bolt I can find but I can't get it off
Old Oct 2, 2011 | 12:27 PM
Franklin2's Avatar
Franklin2
My diesel and I believe some of the six cylinder trucks take a special wrench and the fan clutch unscrews from the waterpump, and it's usually left hand thread. I am not sure about the 460, but if it comes off conventionally, you will need to find a place to pry and try to get it off. I would go to the trouble to buy or scrounge up some thick cardboard to cover the radiator, because if the fan suddenly lets loose, it's a very good chance it will fall into and damage the radiator.
Old Oct 2, 2011 | 12:36 PM
Tknight85's Avatar
Tknight85
I pulled the radiator to make some room I don't see anywhere that I would put a puller on there but that's not saying much
Old Oct 2, 2011 | 03:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The 460 has a fan that bolts to the back of the clutch in four places with a 7/16" head.
The spindle/flange of the fan clutch then bolts through the pulley onto the flange at the front of the pump.
One of those ratcheting combination wrenches helps a lot here. (Gearwrench type)
The funky nut that threads onto the snout of the water pump and needs a super big flat wrench is just for small blocks.
Old Oct 2, 2011 | 03:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There are two sets of four bolts.
The shaft at the back of the fan clutch provides enough room for four to face forward and four to face the rear.
Old Oct 2, 2011 | 03:31 PM
Tknight85's Avatar
Tknight85
I got her off with a few love taps, I'm putting the new water pump on now
Thanks
frank1
13
Sep 25, 2023 11:07 AM
Bowebble
Oct 13, 2014 11:20 AM
SilverSport
Nov 14, 2006 06:43 PM
Irv
May 21, 2003 05:06 PM
gunpowder
Jan 5, 2001 10:26 AM
