How do I remove the MLPS?
Old Sep 30, 2011 | 11:27 AM
LSO1123's Avatar
LSO1123
I'm installing my optishift controller. It has the updated plug for the MLPS. The MLPS on my truck still has the old design so I'm trying to replace it. I took the bolts on each side ot the MLPS out and the nut on the end of the manual shift lever. The MLPS is loose but I can't get the lever off. Looks to me like it has to come off for the MLPS to slide off. I've done a search here and on oil burners as to how to do it but didn't really come up with anything other than threads saying to replace the MLPS.
Old Sep 30, 2011 | 01:29 PM
Lazy K's Avatar
Lazy K
The lever should just slide off followed by the TRS. Maybe try some penetrating fluid to get the lever to move.
Old Sep 30, 2011 | 02:18 PM
LSO1123's Avatar
LSO1123
That's what I was afraid of, I was hoping there was some magic little screw that I didn't see! Lol. I'll soak it with some parts blaster and let it set for a while and see what happens.
Old Sep 30, 2011 | 05:58 PM
LSO1123's Avatar
LSO1123
I got it off. It actually came off really easy! I guess because the last time I tried to take it off I soaked it in parts blaster and then never fooled with it again. New MLPS is on and in the process of installing the optishift!
Old Oct 1, 2011 | 04:21 AM
Lazy K's Avatar
Lazy K
Good man. I take it that, with the trans shifted to neutral, you aligned the two marks before tightening the two bolts.
Old Oct 1, 2011 | 09:53 AM
LSO1123's Avatar
LSO1123
Yep sure did. I didn't know I had to do that until I started reading about how to take it off.
Old Oct 1, 2011 | 11:59 AM
Lazy K's Avatar
Lazy K
Great. I hope you are going to keep us informed about how the install went. Also on setup and your impressions of it compares with stock.
And good luck with the install, hope it goes well.
Old Oct 1, 2011 | 12:12 PM
LSO1123's Avatar
LSO1123
Thanks Lazy, I will definitely update with how it performs. So far the installation is pretty straight forward and simple.
finlander42
Dec 1, 2014 07:18 AM
1984F2506.9
Jan 19, 2014 04:06 PM
Marty1965
1997 - 2003 F150
Aug 31, 2013 07:45 PM
chadgt
1983 - 2012 Ranger & B-Series
Jun 30, 2009 12:42 AM
G2IC_Wraith
Apr 11, 2004 07:05 AM
