HELP - Shift lever removal????
Old Apr 10, 2004 | 10:04 AM
G2IC_Wraith's Avatar
G2IC_Wraith
Question HELP - Shift lever removal????
Ok, so maybe I am a *******, but I am trying to remove the shift lever from the top of the trans. The 3 bolts on the brass cap that secure it to the top of the trans are not the problem. Please refer to the pic. At the base of the shaft is a bolt and nut that dont seem to do anything???? I took the nut off and nothing loosened up. How do you get these two stupid pieces apart????
Edit: I can't seem to get imagestation to work right. The album is here - http://www.imagestation.com/album/?id=4287249843&idx=1 It is image #10 & 11
Old Apr 10, 2004 | 11:03 AM
Dave257's Avatar
Dave257
OK. take the nut off and put it on the other side. as you tightn it, it will pull the pin out and free the handle.
Dave
Old Apr 10, 2004 | 11:22 AM
G2IC_Wraith
Thanks for the reply. How tight? Do I need to bang it or anything? I did try the nut on the other side while I was just out side and the groove on the other side seemed to shave off some of the bottom part of the nut the tighter I went.
Old Apr 10, 2004 | 03:11 PM
Dave257's Avatar
Dave257
Mine came right out
It should come right out, ford manual uses the trick. don't bang on it.
Dave. on My 98 it worked like a charm. it is a tapered pin and it wedges the shifter on. Are you sure your on the correct side?
dave
Old Apr 11, 2004 | 07:05 AM
G2IC_Wraith
Yea, I was on the right side. The part that worried me was that side is shorter and there is a groove in the base. When I torqued it down the groove cut a shaving off the bottom of the nut. It was just frozen a bit. I torqued it a bit more and tapped it with a rubber mallet. It finally fell off. Thanks.
