Just installed new Rancho steering stabilizer on my 2004 250 sd ( it was missing?!) and noticed top of front tires sit approx 1" inboard than bottom of tires. is this normal or does this indicate need for new balljoints/tierod ends? Or is the cant not set properly? Would post pics but dark outside now and pics not showing cant as it really is. Did not drive it yet but did turn wheel fully right and left as install instructions requested and have new stabilizer has no contact with any thing.
Put the front up on jack stands and check for play in the front wheels. I don't think there is that much camber adjustment, so it's got to be really, really bad ball joints or main bearings.
Would turning the wheels on dry pavement cause tension to the point that the wheels look tilted in? Will drive it in daylight to see if it sits true tomorrow. If tilted then will lift each and check play. Thanx.
It changes all the time depending on how you stopped the truck. Toe has some to do with how the tires appear to sit. If you have toe in the tires will appear to have massive camber if you parked the truck after backing up.
Only ways to know is jacking it up and checking with a bar or if a wheel falls off on the highway.
Hahahahha...................oooooopppppsssssss. Not funny!
Yup that is how I parked it. Will check after a drive but at work now so have to wait till I get home this afternoon. Have car at work
If the top is tilted in, that is camber. And they should stand almost perfectly vertical when tires are pointed straight ahead. They will tilt in or out when tires are turned.
If the front or rear of tires are pigeon toed in or out, that is toe in.
If yours are truly tilting in a full inch, you should be noticing wear on the inside shoulders of the tires.
After driving the truck around for 30 mins and parking it on level ground found tires were not cambered in very much at all and no undo wear on inside portion of tread, therefore figure it was how it was parked and since tires have been on it severaal months that balljoints are decent. Will verify no slop in balljoints at a later date, but thanks so much for the advice guys
If the tire was visibly tilted in like that than I would not wait until a "later date" to check as they are most certainly bad! Just saying...an ounce of cure ect...ect...
Jim & fat Monty
