1978 - 1996 Big Bronco
front wheels woble while going forward
Old Jan 23, 2012 | 09:00 PM
martinbarrio's Avatar
martinbarrio
Unhappy front wheels woble while going forward
my front wheels wobble while i'm going forward and i turn a bit to the right i'm rolling on 32" tires what could it be I've checked every thing and everything is in good shape . any help would be greatly appreciated thanks martin
Old Jan 23, 2012 | 10:09 PM
AbandonedBronco's Avatar
AbandonedBronco
If your tires wobble then it doesn't sound like things are in good shape.
What all have you checked? Loose wheel bearings? Ball joints? Lug nuts torqued in proper sequence?
Have you checked underneath for cracked or broken support parts?
Old Jan 23, 2012 | 10:17 PM
GruesomeJeans's Avatar
GruesomeJeans
Ahh you had the same issue as a few of us 78ers... Ok so have your tire checked for separation. Then slide under and look for you Trac-Bar, goes from the right side (passenger) of the front axle to the left side under the steering box and have someone turn the wheel back and forth and see if there is slop in the bar where it bolts on. If there is then you need new bolts and bushings. You could also look into changing the steering stabilizer shock if you have one. Other than that bearings and ball joints and that stuff is whats left.
Old Jan 24, 2012 | 10:17 PM
martinbarrio
thanks for yur guys help ill look into what you guys said thanks again
Old Jan 24, 2012 | 11:17 PM
GruesomeJeans
Yup no problem.
Muddy Creek
15
Nov 13, 2015 03:35 PM
JOHNNYRICH10
Feb 21, 2012 08:49 AM
Wisebuck
Oct 1, 2011 08:49 AM
jimford1
Aug 27, 2008 05:58 PM
timothy47129
Feb 10, 2007 09:31 PM
