Proportioning valve orientation
Old Sep 29, 2011 | 11:28 AM
Handegard's Avatar
Handegard
Is the proportioning valve mounted like a I or like a ----?
If that doesn't make any sense, does the rear brake line exit the valve straight back, or down and then make a 90* angle?
Old Sep 29, 2011 | 01:10 PM
mark a.'s Avatar
mark a.
The rear brake line exits the valve straight back. I don't see any reason why it could be mounted any way as long as it's mounted lower than the master cylinder.
Old Sep 29, 2011 | 01:50 PM
78longbed's Avatar
78longbed
Yep, straight out the back of P valve for the rear brakes on my 78 F250, then slightly downward bend, then hugs the inside of frame back to the flex hose for the diff.
Old Sep 29, 2011 | 02:41 PM
gregb's Avatar
gregb
I would post a pic for ya, but apparently I'm too new or not a member or something.
Old Sep 29, 2011 | 02:59 PM
ctubutis's Avatar
ctubutis
This might help:
User Gallery & Picture Display Help - Ford Truck Enthusiasts Forums
Basically, upload your pics to a hosting site, then paste the URLs into your posts here (easiest if you use the "Insert Image" button on the Advanced editor).
Old Sep 29, 2011 | 03:32 PM
Handegard's Avatar
Handegard
I'm sticking a '79 P-valve on a '68 that is getting front disc brakes....
I took the valve off over a year ago, and don't recall it's orientation...
Old Sep 29, 2011 | 08:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's how it's mounted on a '73 F100. The line on the left goes to the rear.
Old Sep 30, 2011 | 07:09 AM
gregb's Avatar
gregb
Yep. That's what they look like on the 79 4x4s too
fasthauler
Sep 21, 2016 10:39 PM
xdgt03
Oct 18, 2007 07:35 AM
71 Sport Custom
Jun 4, 2005 09:02 PM
84-250
Oct 2, 2004 04:40 PM
uk1050
Nov 3, 2003 11:46 AM
