General Automotive Discussion
Post Overheating Help
Old Sep 28, 2011 | 09:53 PM
khadma's Avatar
khadma
Carpenter Local 745
1999 Taurus 3.0 auto
Overheated then shut down.
The engine will turn, but not start.
Could there be timing chain issues?
Fuel to the rail.
I have to check spark now.
To this point I have the coolant sensor DTC cleared.
No other codes.
Old Sep 29, 2011 | 12:05 AM
Ford_Six's Avatar
Ford_Six
3.0 Vulcan or 3.0 DOHC, and does coolant poured into the radiator stay there or disappear?
If it's the Vulcan (pushrod), then check for spark and compression. If it overheated until it died then it probably has multiple stuck valves, and may have cracked heads.
If it's the DOHC- Engine shopping time. Cracked heads are quite certain in a major overheat with aluminum heads.
Old Sep 29, 2011 | 02:46 AM
khadma's Avatar
khadma
Carpenter Local 745
3.0 Vulcan OHV.
I have to check overflow/fill tank tomorrow.
I may remove valve cover to check valve train, after reading your post
when we try to crank it there seems to be binding somewhere.
I hope it is only top end.
93nighthawk
Aerostar
18
Feb 1, 2015 01:41 PM
fenix1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 30, 2008 08:43 AM
Jocaren
Sep 21, 2007 09:37 AM
webguyrich
1983 - 2012 Ranger & B-Series
May 1, 2002 10:11 PM
