Check Engine Code Light
Old Sep 28, 2011 | 05:23 PM
Brian085's Avatar
Brian085
88 f150 5.0 EFI
Code seems to read as follows
| = Check Engine Blink
This is 41 53 35 33 or what?
This was done with Engine off. So KOEO.
With KOER (key on engine running) I'm seeing 4 blinks and an increase of engine idle RPM to 1800 when normaly 1000.
Thanks
Old Sep 29, 2011 | 04:59 AM
EPNCSU2006's Avatar
EPNCSU2006
There should be a separator pulse in there between two groups of codes. Each group of codes will be flashed twice. See here: EEC IV Self Test hookup
The KOER test will blink 4 times for a V8, then do some tests of sensors/actuators, then possibly give a single flash which is your cue to give the throttle a quick stab, touch the brake pedal, turn the wheel 1/4 turn, and push the O/D cancel switch (if there is one). Then it will output any codes.
Old Sep 29, 2011 | 05:42 AM
Brian085's Avatar
Brian085
I'll give that a shot. Its also a 4 speed so no OD botton.
cjben
19
Aug 16, 2008 12:32 PM
mike L
Apr 9, 2006 08:19 PM
turboguy
Apr 23, 2005 09:50 AM
_GEEZER_
Electrical Systems/Wiring
Apr 11, 2004 12:40 PM
itsn0tus
Feb 19, 2002 11:53 PM
