Checking for KOEO codes
Old Apr 7, 2006 | 11:06 PM
mike L's Avatar
mike L
To do a KOEO test first warm up the engine. Then turn off the engine and attach a jumper wire. Restart engine and the light will flash 4 for an 8 cyl. Right after this, depress the brake and release, if you have the 5.0L with P/S switch, move the steering wheel about 1/4 turn in either direction then back to where you started. Then momentarily go to wide open throttle and back to idle. Then get ready to read the codes."
I did this test and only got 4 flashes for my 8 cyl. Is it a must to do the brake, steer and throttle procedures, could I have trouble codes I don't know about?
1993 F-150 5.0.
Old Apr 8, 2006 | 05:54 AM
EPNCSU2006's Avatar
EPNCSU2006
There should be four flashes for the engine code, then a single code telling you to goose the throttle and turn the steering wheel and push the brake pedal. Then it should begin blinking codes soon after that.
Old Apr 8, 2006 | 06:20 AM
LoosMaster's Avatar
LoosMaster
My book says to do the Brake and P/S right after the engine ID, then wait for the single flash. Also, if you have a AEOD, you need to cycle the cancel switch during the brake and P/S or you'll get a 632.
Old Apr 8, 2006 | 06:30 AM
EPNCSU2006's Avatar
EPNCSU2006
There should be a single flash for the "goose code"
Old Apr 8, 2006 | 06:48 AM
LoosMaster's Avatar
LoosMaster
There is but my instructions say to do the Brake, P/S and O/D switch(if equiped) immediately after the Engine ID, then wait for the Single Flash for the "goose" test.
Old Apr 8, 2006 | 02:16 PM
mike L's Avatar
mike L
Thanks, I only get 4 flashes nothing else. I have a E4OD to, so I should of got a 632 code. I'll try again.
Old Apr 8, 2006 | 05:42 PM
LoosMaster's Avatar
LoosMaster
Mine almost takes a full 9 seconds before the flash for the "goose" test.
Old Apr 9, 2006 | 07:47 PM
EPNCSU2006's Avatar
EPNCSU2006
Yep, the computer tests a bunch of stuff on its own before it asks you to goose it.
Old Apr 9, 2006 | 08:09 PM
mike L's Avatar
mike L
Just got run for 5 minutes then checked codes, turned wheel, brake and throttle, it took about a minute before the lite started flashing.
KOEO
636 TOT sensor voltage out of self test range
KOER
116 ECT out of self test range 0.3 to 3.7 volts
311 Thermactor air system inoperative (right side)
538 Insufficient RPM change during KOER dynamic response test/ Operator error
632 Overdrive cancel switch not changing state (E4OD)
Don't think i need to worry about codes 538, 632. Can i get the other codes with only a fuel problem? Idles fine after it warms up, runs rich and has sooty plugs. Whats a tot?
Old Apr 9, 2006 | 08:13 PM
mike L's Avatar
mike L
once it warmed up longer 116 did not show up again.
Old Apr 9, 2006 | 08:19 PM
mike L's Avatar
mike L
636 tot= trans oil temp. i didn't go for a ride first. So, only code 311 is left then?
