New problem with transmission
Old Sep 27, 2011 | 10:00 PM
ihf-350's Avatar
ihf-350
After the tranny shop I replaced tps fixed the hard shifting and it no longer starts out in third but now t will stay in 1st until I let off the gas then shifts to o/d real fast and the rabs light is on and the brakes are good and the vss is new don't know where to go from here please help thanks
Old Sep 27, 2011 | 10:14 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
tps is out of adjustment.where did you set the new one at? or i guess the better question first would be; did you read up on how to properly set the tps yet?
edit/seek your other thread found here:
https://www.ford-trucks.com/forums/1...g-right-2.html
we'll get that E40D shifting like a dream (probably no such thing without a shift kit though.)
Old Sep 28, 2011 | 11:13 AM
eatont9999's Avatar
eatont9999
Mine kind of does that but it doesn't go from first to O/D! That is probably pretty bad for the transmission and engine.
When I accelerate, sometimes I will get up into 2500RPM+ before the transmission shifts on its own. If I let up on the accelerator at 2000, it will upshift. Same goes for all the gears.
I think I have my TPS set at 1.08-4.38v I think I need to close the range a little and bring the 4.38 down to 4.0 or less. Maybe 3.88?
Old Sep 28, 2011 | 07:49 PM
LSO1123's Avatar
LSO1123
Ya know, I've never been able to get my TPS to adjust above 3.65 on either one of my trucks! No matter what I set the idle volts to the WOT volts will be between 3.56 and 3.65. On my '94 I think maybe its because my pigtail is loose and not getting a good connection with the TPS so I have a new one that will be installed with my optishift. On my '93 I have no idea why it won't go any higher than that at WOT.
Old Sep 28, 2011 | 09:36 PM
ihf-350's Avatar
ihf-350
sorry not 1st straight to overdrive it went through the gears just a lot faster than it should have and now that I drove it for a day it seems better dose the e40d have to relearn cuz now its shifting good still have the rabs light on though
parkland
Jun 10, 2019 10:18 AM
Golden Helmet
May 15, 2015 07:48 PM
Rellick
1997 - 2003 F150
Jul 27, 2014 09:33 PM
eatont9999
Jul 6, 2011 11:19 PM
SuperHighOutput
Nov 13, 2005 07:31 PM
