quick question
Old Sep 27, 2011 | 07:31 PM
rangergirl94's Avatar
rangergirl94
quick question
how do i remove the headlight and wiper ***** i dont wanna break them
Old Sep 27, 2011 | 07:48 PM
Franklin2's Avatar
Franklin2
This picture shows the way to get the wiper **** off, and also the headlight switch **** on some trucks. I will warn you though, it's hard to do even if you have the right tool to do it. On the headlight switch, you can also disconnect the battery, pull the headlight switch **** all the way out, and then feel around the switch for a button(behind the dash). If you find the button, push it down and then continue to pull the headlight ****, and the whole **** and shaft will come out of the switch. Some trucks though, you can't get your hand behind the dash and around the switch to get to the button.
Old Sep 27, 2011 | 08:38 PM
ctubutis's Avatar
ctubutis
This is the button Franklin is telling you about:
Daniels54
Sep 23, 2016 05:14 PM
Monana ford Man
Jan 9, 2012 07:33 PM
Pastortom1
Aug 23, 2011 10:55 PM
dhobdey1
Nov 28, 2009 08:39 AM
gary678
Electrical Systems/Wiring
Aug 30, 2006 08:30 PM
