Guys........Clue me in on the simple way (please tell me it's simple) to remove the headlight and wiper ***** on my 83 F-100 so I can GET THE DASH BEZEL OFF...........
Have to clean and refinish the plastic dash........STUCK again.......
Need a PRO like you'se guys to chime in here...........
For the wiper ****, you have to remove it like the picture below with a sharp pick or other tool. Don't get frustrated, it's pretty hard to do and sometimes I end up jerking the **** off, but it's hard on the wiper switch.
For the headlight switch, you can reach up behind the dash and feel around on the side of the switch opposite the wires. There will be a button. Go out and take the battery cable off, pull the headlight **** all the way out, and then push on the button and pull again, and the whole **** and shaft will come out.
Just as a little tip, if you have any of those tiny eyeglass screwdrivers laying around, take one and bend the tip into an L shape. You can then use the end of the screwdriver to get into the little notch of the *****, and then depress the spring and remove the *****. If you stick the screwdriver in correctly, the bent end of the tip should be facing the ****, while the shaft of the screwdriver shall be pointing towards you. Pull the shaft of the screwdriver towards you to depress the clip, and at the same time pull on the ****.
Already bent a special tool out of a key ring......Just what the doctor ordered.....BUT the headlight switch is worse than any I've worked on in the last 40 years........you gotta be a chimpanzee to get in there......
