What is a hard code?
Old Sep 27, 2011 | 03:58 PM
2wheels06's Avatar
2wheels06
Cannot get any codes from computer. it says to clear hard codes first can someone help? i have a 95 f150 5.8 351w with an e40d tranny
Old Sep 27, 2011 | 04:28 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
HARD codes are codes which turns the CEL on......
Old Sep 27, 2011 | 07:17 PM
projectSHO89's Avatar
projectSHO89
No. "Hard" codes are ones that not intermittent. It refers to a fault that is unambiguous. A completely and continuously faulty device or sensor would be considered to be a "hard" fault.
Of course, if you cannot pull any codes, you likely have some hard failure.
Old Sep 27, 2011 | 07:36 PM
Franklin2's Avatar
Franklin2
Check this out and see if it helps.
Ford Fuel Injection » No Codes?
Franklin2's Avatar
Franklin2
Old Sep 28, 2011 | 05:35 AM
2wheels06's Avatar
2wheels06
thank you for the help i will try some of these things and if you have any other ideas please share cuz my tranny guy and i are both scratching our heads. talked to him yesterday and he said he unpluged the tps and said it help some when going into drive but still its very hard going into reverse
Old Sep 28, 2011 | 07:03 PM
2wheels06's Avatar
2wheels06
got the problem fixed it was a broken wire between the computer and the tranny. once did the scanner right got a code and ran with it. was not doing the koeoff test the tranny guy though you would get same codes by skipping to the koeon test. oh well it happens
Maathiu Ra Yin
Electrical Systems/Wiring
Oct 18, 2016 09:37 AM
tcroson
Apr 1, 2015 05:50 PM
bocefusss
1978 - 1996 Big Bronco
Jun 6, 2007 04:09 PM
lowdownndirty
Apr 10, 2006 01:22 PM
czabala
Computer Chips & Tuners
Sep 14, 2004 01:18 PM
