I'm almost pos that I have some of those connectors at work. I searched through the International schamtics, but nothing shows p/n for the pins for the injector. Im guessing its the connector on the injector itself and not the engine harness, correct? When I get to work tomorrow Ill look in my box. If i dont have just the pin i know i have the whole pigtail for the injector, and that is something I dont think you can buy... I have a huge box full of International pins, connectors and pig tials that I will go through if no one else chimes in.
Yeah...... it is the pin on the injector side socket. Very small crimp on. I managed to pry the old crimp on off, but I seriously doubt I can braise another piece of copper on the end to replace the part I broke.
If you have a complete pig tail I will pay you for your troubles if needed.
I managed to remove the crimp on pin/connector last night. The crimping side of the connector is re-usable, but I seriously doubt I can braize another copper pin back on it though.
Ok so the only thing I could find in my kit was the engine harness side pig tail. I talked with parts and he said there's no was to break the injector connector down, and there's not a pig tail for it. What I can do though is I have to replace a few injectors today and I can cut the old harness off the old injector if you want. Just let me know. Also where are you located?
