injector problems
Old Jan 28, 2012 | 04:42 PM
alexisvfd's Avatar
alexisvfd
injector problems
i have a 2004 f250 diesel 6.0 and i have the number 1 and 3 injector out..my connector that clips on and the metal connection clip hooks to is burnt a little..is there anywawy i can replace that piece
Old Jan 29, 2012 | 06:04 AM
npccpartsman's Avatar
npccpartsman
The FICM harness is one complete piece from the FICM to the injectors and the injector harness requires that you pull the injector IF you can find someone to donate you the harness/coils from an old injector.
Old Jan 29, 2012 | 06:39 PM
alexisvfd's Avatar
alexisvfd
ok i heard you couldnt replace them then i heard you could just hard wire them.
Old Jan 29, 2012 | 07:31 PM
npccpartsman
If you try to hard wire it where the injector connector comes through the rocker box you'll have an open hole that will have blowby puffing out of it all the time and/or dirt going in all the time. You can see the consequences of that, I'm sure. Spend the money and fix it correctly and avoid problems down the road. You'll be money WAY ahead in the long run.
Fldiesel73
Nov 8, 2016 07:37 PM
mudfuel06
Dec 11, 2015 05:39 PM
hotrodfeguy
25
May 16, 2015 09:09 AM
Jay Fletcher
Apr 7, 2013 10:33 AM
Rick2001
Feb 7, 2007 03:21 PM
