Accidentally used green handle filled excursion with unleaded my 6.0 diesel got half mile away before figured it out loud knocking. Tow truck in route, best solution? Thanks in advance
Drain the tank, fill with #2, purge the lines, change the fuel filters, and keep on truckin.
Remove the upper fuel filter and cycle the key until diesel is up in the fuel bowl. Then you know the lines from the tank are mostly free of the gasoline. Change the fuel filters after that.
