Sponsored by: Real Truck
HELP NEEDED - Drain Fuel Tank?
Old Jan 8, 2005 | 01:44 PM
kjensen's Avatar
kjensen
Does anyone know how to most effectively drain the fuel tank on an 03 F350 dually, 6.0? I need to get about 30 gallons of GASOLINE out of the tank before I can change the filters and REFILL it with DIESEL... It's a BAD DAY...
Any help would be appreciated...
Kevin
Old Jan 8, 2005 | 02:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by to answer your question.
Enjoy FTE …..
Old Jan 8, 2005 | 02:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Siphon out all you can get out that way, then refill it with #2 diesel. The percentage of gasoline left should be small enough to cause no problems. If the lines have straight gas in them I would also try to drain it out before starting it.
Old Jan 9, 2005 | 11:16 AM
kjensen's Avatar
kjensen
Thanks Dave -- I managed to get it done. I got pretty frustrated because all that I read said to "drain" the tank. I couldn't find any way to drain it... So I finally got a siphon tube down the filler neck and got it siphoned. Changed filters (getting as much gas out of the system as I could) refilled with diesel and ---- All is fine.
The dealer really scared me, saying that probably all injectors would have to be replaced (at 400 each)...
Thanks for the help.
Kevin
Old Jan 9, 2005 | 12:42 PM
99f350sd's Avatar
99f350sd
So how does it run on gas? I'm just currious!
RBerry9511
Sep 30, 2014 09:45 AM
DougJ_1997PSD
Jun 11, 2014 05:56 PM
DougJ_1997PSD
Jun 11, 2014 05:31 PM
Sweetness_81703
Mar 28, 2011 08:08 AM
Karstonian
Aug 28, 2004 08:44 PM
