351 build
Old Sep 25, 2011 | 10:36 PM
deve's Avatar
deve
351 build
first of thanks for all the help when i built my 302 a while ago but i should had listen to some of you guys when you said go with the 351W . so now i am going to build me a 351W. the block's # are E9AE i think im not sure. not at the house could somebody tell me if the block is roller or not i know it dosent have a roller cam. i was wanting to build a pretty mean 351 i heard you can use a 3.85 crank stock rods and .30 over 302 pistons and have a 393 stroker.
my plan is
3.85 crank
stock rods
302 pistons
performer intake
1406 edelbrock carb 600cfm
35-246-3 - Xtreme Energy
pro comp heads
i was hoping for a truck that could runs high 12's low 13's i am using the aod 2400 stall 4.10 gears by the way the truck is a 89 f150 longbed. also what is some opinion's on stroking the 351. thanks for the help
Old Sep 26, 2011 | 06:10 AM
HemiEater's Avatar
HemiEater
with that cam I would use an rpm or rpm air gap intake and a holly 750cfm or bigger and make sure you use a dish piston that will get you the proper compression. check into a balanced rotating assembly there are a bunch of then out there...
My 2 cents...
Old Sep 26, 2011 | 06:29 AM
HemiEater's Avatar
HemiEater
I used that cam in a 302... had a great ideal but the valve train had a clatter to it that I could not figure out.. I checked and checked and checked everything ended up changing the cam because I could not stand the noise. Do a search on XE274 noise and if you find a link to Ford Muscle user 393Clevor that is me... I had bad valve guides do to valve geometry not be right I fixed that and still the noise would not go away.. a lot of people complain about that cam being noisey
http://www.fordmuscleforums.com/all-...s-rockers.html
Old Sep 28, 2011 | 11:20 AM
deve's Avatar
deve
how noisy are we talking about only hearing it under the hood or the car next to you at a set of lights. are there any problems with using the 393 or should i go a different option none of my plans are written in stone yet. i was thinking about going with a 700 or 750 carb but then i thought that may be to much carb for the engine and it is a truck so i would want great throttle response
Old Sep 28, 2011 | 11:27 AM
HemiEater's Avatar
HemiEater
I'm confused with your build... 2400 stall, tall gears... I wouldn't worry about throttle response...
very noisy like it had solids in it... but only above 2500 or so, some people never have a problem with it, some do.
Old Sep 28, 2011 | 01:25 PM
deve's Avatar
deve
the truck will be daily driven but i drive very hard and spin the tires daily. i just dont want to have to lay down hard into the throttle if i want to get moving or spin the wheels. but me driving daily inst that much only 15-40 miles a day tops. i was thinking wouldn't the performer have even a lower power range now because the motor is stroked and need more air so would the rpm act more like a performer.
Old Sep 28, 2011 | 01:34 PM
Kemicalburns's Avatar
Kemicalburns
what tranny will you be running?
you will have to get on the throttle for the stall to work so what your saying doesnt make much sense. i would keep the stock stall speed personally.
is this truck 2wd or 4wd?
HemiEater's Avatar
HemiEater
Your combo is going to be a beast for sure I would lose the edelbrock for a holley at least a 750VS or bigger and run a rpm or air gap... which heads were you thinking about? and take it from me a 2400 stall in a truck wont last long without a huge cooler with a fan. I cooked my 3000 stall in my 85 4x4 302 with that same cam.. way to much stall and cam for the weight in a street rig... anything below 2400 is slipping the converter and causing heat... you might want to tighten up the converter and run a smaller cam, it will still roast the tires trust me.. just go small on the intake ports...
Old Sep 28, 2011 | 02:43 PM
deve's Avatar
deve
the truck is a 89f150 longbed 2wd aod tranny. the stall converter is a b&m 2400 locking so i figured overheating wasnt going to be a issue. lol well i already have the stall converter from my first motor build i built a 302 that had no low end at all so i bought the stall converter and the gears. i had never even got to install the converter. i had to sell the motor when i got married to buy rings. why go to Holley i had the Edelbrock on my first build and loved the carb.
the head i am going to choose from are
289 302 347 351w 5.0 Ford Procomp Aluminum Heads 190cc | eBay
289 302 347 351w 5.0 Ford Procomp Aluminum Heads 210cc | eBay
Old Sep 28, 2011 | 03:12 PM
HemiEater's Avatar
HemiEater
It's just what I like I can tune them in an hour or so.. plus they make more HP hands down.. at least in my world... I would go with the 190cc runners with your build.. leave the 210 for the high rpm HP motors... again thats just my 2 cents other may feel different.. the 190cc runners will have more low rpm velocity for better throttle response..
Old Sep 28, 2011 | 03:59 PM
Kemicalburns
you will need a flexplate from an 88 crownvic 5.8/aod combo. but honestly your gonna have to spend some coin on the AOD to hold up behind that motor. they barely hold up behind a stock 5.0.
Old Sep 28, 2011 | 04:05 PM
HemiEater's Avatar
HemiEater
I have to agree I built one, Ford Motor Sport wide ratio gear set hy rev governor kit bla bla bla non-lock up converter and shaft, manual shift kit $$$$$$$ didn't last very long but it was nice while it lasted ran 4.56 gears with a 4 speed automatic with 3000 stall was fun ... got the gear set for sale if your interested
Old Sep 28, 2011 | 08:07 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
E9 isn't a roller block but you should take the time/spend the money to find one. Either that or pony up for some linked lifters. Especially with a stroker. The faster ramp helps a ton when you're gulping in 50 cubic inches of air per cylinder. Plus no worries with break in.
Can't remember the name but there's a bunch that sells an AOD they claim handles 600-800 pd/ft. With a converter for ~$2,000. Big chunk of change. May be cheaper than tow jobs and a couple of rebuilds in the long run if you're really going to be romping on it like you say.
Old Sep 28, 2011 | 08:10 PM
deve's Avatar
deve
TCI Auto 438905 - TCI Pro Super Transmission Overhaul Kits - Overview - SummitRacing.com this was the tranny rebuild i was looking at getting but if the aod cant hold much power what tranny would you use. but i am still planning using the aod because of overdrive and i would not go with a manual automatics are the way
Old Oct 2, 2011 | 10:51 AM
Conanski's Avatar
Conanski
Those ProComp heads don't work that well out of the box so this won't be a 500hp motor or anyhting.. more in the 350hp range but it will make boat loads of TQ.. your 302 is a 90lb weaking in comparison. If you want something that could be mistaken for fuel milage and a vehicle that will have recognizable street manners then I'm also gonna suggest a stock like lockup converter for the trans and a cam that is a bit milder than the one you posted, maybe the Comp 35-238-3 or 35-242-3. You also won't need a giant carb here either, something like a 650 vac secondary should do quite well and provide very fast throttle response.
boingk
Oct 2, 2016 07:48 AM
The Confederate
17
Mar 29, 2012 03:34 PM
jeff5683
Jul 9, 2006 08:48 AM
f100guy
Feb 4, 2005 07:51 AM
wolfsrgrt
19
Aug 17, 2003 10:46 AM
